to Bob M I have a 53 farmall Super C I leave the tractor sit for 2 weeks at a time and when I come back to use it the battery has drained. I had been disconnecting the battery ground cable to keep that from happening. however in my searching I found out the generator needed polarizing. Then I was told if Ikept removing the battery cable I would have to repolarize the generator. What is your advice. I do have a trickle charger but during the 2 weeks I gone I have no electric. Once I return I turn on the electricity and plug in the trickle charger It charges up the battery. what do you advise?
