IAtractorKid
Hey guys! Friend asked me to take a look at his H; said he thinks it needs a new throw out bearing.
So, it looks like he has about 3" free play in the pedal but unfortunately it also looks like he is about out of threads on the adjustment rod. Tractor shifts into gear just fine but you feel a vibration in the pedal just as its released. The clutch shaft chatters left to right as well...I cant remember if that was in gear or just neutral.
Thoughts?
I thought I may try and adjust it if there are enough threads and see what that does. With that much free play and the adjustment rod already almost out of threads wouldn't you think the clutch is on its last leg?
Thoughts?
