240u zenith carb id
glennster
i need to get a carb kit for my international 240 u. has a zenith carb but i couldntt see a number on the carb. its still on the tractor and i dont want to pull it apart before i get a kit. yt shows several kits for the zenith.. z102 or k2119 are two that kinda look like a maybe. any guesses??
There should be a dime size brass plate fastened to the throttle body which is visible from the top - don't recall if on the front or back side with the part no. in small numerals and letters. All 240 (Farmall and Intentional) models have the later C-123 engine with the engine s/n greater then 65001. The IH TC-53 parts catalog which includes the 240 tractors lists the original Zenith as p/n 367822R91. If Rustyfarmall sees your thread he can probably give you more information, Hal.
