International model 35 hay rake wont stay in gear???
longhornguy
New User
my model 35 hay rake wont stay in gear and I cant seem to find the problem. It is ground driven, when I put it into gear it will pop out after a few feet. I replaced some bearings and the shift fork last year and that didn't make any difference. Has anybody else had problem like this or something similar? What was the issue? Thanks in advance any insite is greatly appreciated
If the clutch splinrs are worn to a taper, and the external splines are rounded, either replace, or use a Dremel and diamond bit to
retaper them to lock together some. Jim
diagram
(quoted from post at 14:04:56 05/29/17) If the clutch splinrs are worn to a taper, and the external splines are rounded, either replace, or use a Dremel and diamond bit to
diagram
Awesome I'll check it tonight thanks
