bearhunter
New User
Hi I am new here so hoping someone can help.
Picked up a 986 and after getting it home changed all oils and filters and found a defective lube sending unit on mcv , replaced , adjusted clutch ,ta ,dump valve,& trans brake as to blue book service manual , then after using tractor about 20 hrs. lube light would not go out till over 1500 rpm so done some press tests and found pump press way low so replaced mcv pump from HI Capacity plus rebuilt mcv valve with all new springs, gaskets & o rings , oil & filter again , ( old pump was wore out bad) redone all clutch , ta, ext ext again now every thing is good I thought till after 5 hrs. disking yesterday when I stopped light was back on as soon as I got down to 1500 rpm , now I am lost where do I look ? I am a heavy duty mechanic and have worked on just about everything from D2s to D8s, case, mf , jd , cockshutt but never a IH other than engines :?
