mattofvinings
I am scheduled to go pickup my grandfather's SMTA from NE Iowa and relocate it to SE Michigan next month.
I'm working on tie-downs and discovered this pic, I would like to duplicate this technique if possible. I'm wondering if someone knew about these vertical holes thru the front bolster, what is the diameter, and is it a thru-hole where a Gr5 nut+bolt would work as the pin? I don't have the tractor near me to figure this out currently. It appears from image searches that the 400 has the same casting on it. Thank you in advance if you can help.
