Dave H (MI)
Good news is, I am 100% planted and we got a little rain. Bad news, the 300U won't start this Spring and I need it to pull the sprayer in a couple weeks here. So, to update, I had a bad battery isolation switch and I have a replacement but currently I am just bypassing the switch to make life easier. The starter has been tested by a good guy and is working fine, no drag. I replaced the solenoid as it went bad. I have a brand new charged battery because the old one was questionable. So I have moved over to the other side of the engine and am testing the ignition. My handy dandy probe tester flashes when put on the distributor side of the coil. I pulled the plugs and they are old, so I replaced them all on spec. When I lay them against a ground and crank the engine I get a yellowish spark...not the hot blue spark I would hope for. I gave it a breath of starter fluid and it sounded like maybe it fired on one cylinder one time, but no more than that. I am wondering if my coil is weak? How would I know? This tractor was running last fall when I drove it into the shed. Any suggestions welcome, I am only an amateur mechanic. I get it done, just takes me a long time and a lot of head scratching.
Thanks!
Thanks!
