johndeeregreg
trying to get my M so it will run smooth, at low idle it runs smooth and just whispers along but when i open it up to high idle it surges like its switching between the idle and load circuits. i try adjusting the idle screw (the one by throttle shaft that's at an angle) with it running wide open and think i get it running a little smother for a second or two then it goes right back to its surging. I'm not sure where i have the idle or load needles as fare as turns open goes. i have had the carb off at least twice and went through it and both times i thought i had all the passages cleaned out. what am i missing? i have been through the governor adjustments using the I T manual so i'm pretty sure i have all that adjusted right just seems like my issue is with the carb to me.
will an M run as smooth as an H or super H? my neighbor has both and they run really smooth compared to my M
