Good evening everyone. Hope all is well.
So as it says I have a 49 Farmall cub. I got a new Governor for it and had help to put it in. When putting it in there were 2 dots on the teeth of the flywheel or gear teeth whatever its called. And 1 dot on the gears of the governor. The one dot was put in-between the 2 dots. Govenor was then installed.
Now after watching some videos and such i found i was suppose to find top dead center on first cylinder on the compression stroke. Lined up the little needle indicator on the notch on the pulley. From what i understand this is suppose to bring the governor notches to 2 and 8. Mine are at 10 and 4. Any idea how or what to do to fix this. Any help would be appreciated.
