Cyclo 800 help
I have a cyclo 800 planter with row markers but don't have the marker switch I have read several posts and understand that a red and green wire goes to one solenoid a red and orange goes to the other the black wire is a ground two wires go to pressure switch my question is how to wire up a toggle switch for each solenoid to work the markers I have read about people doing that and working but no details as how to wire it up to work any help appreciated
I wired a toggle switch for my nephews planter several years ago.
It doesn't work automatically with pressure when raising.
Has to be switched manually every time the planter is raised/
lowered.
Use a single pole double throw center off toggle switch up on
the tractor. Connect 12 volts to the center terminal on the switch.
You will need a 2 wire cable to run to the planter back by the
marker solenoids. Connect either wire from this cable to 1 of the
outside switch terminals, & connect the remaining wire to the other
switch terminal.
At the solenoids connect the 2 black--ground wires together &
use a piece of wire to connect them to a convenient ground on the
planter frame.
The 2 wires from the tractor connect to either solenoid "hot" lead
wire. 1 lead to right or left solenoid.
You will have to have the switch in the right or left position depending
on which marker you want to use when lowering or raising the planter.
The switch can be in the center position while planting---the solenoids
won't be energised.
Jim
