1939 Farmall A wheels and steering box
What is the proper wheel color for a '39 A? Also the front axle pivot/lower steering housing on my A is broken, but has been repaired enough to work for show. I have top and bottom steering housing from an unknown year Super A. Is there any difference in mounting between these housings? I may be able to have the original repaired but it may be quicker to replace it.
Center hub is RED and Rims are Silver. Depending on where you got the replacement there could be a difference on the center link where it fastens to the out-put shaft.When new it was square later ones were tapered.
