1466 wiring harness
urbancase
I have my 1466 in the shop having new clutch and TA put in, its my oldest tractor that I bought when I started farming and taking over from dad and my uncles. anyway I plan on using it this summer then this winter do a good sheet metal clean and sand and repaint and fix all the other small items. I need to replace the wiring harness and would like to put it all in from new, do you guys know of a place that makes them? thanks for the help.
myself i build all my own harnesses color code correct and with heavy duty wire ends . the male and female plug ins are delco 56 ends and the plastic plug in's can be bought new , only use the black plastic ones . The one thing i do different is the main feed from the alt. back i use and 8 ga wire over whats in there from the factory . I do this because today we use more stuff that draws more amps then just lights and charging the batterys.
Call Agri Services in Alden New York. They have excellent quality and good people. All OEM colors and connectors. You cant build one for what they want. 716-937-6618 or wiringharnesses.com
You might price them at your local Case IH dealer. A few years ago I replaced all the wiring on my 856.
I checked several harness suppliers online and found the dealer beat them on price with a genuine part. Sure is nice to work with new supple wire with all new ends. :)
