Pneumatic Lift-All
Moonlite37
Was the pneumatic lift used on some of the F 12 o F14. Did any other manufacturers use something similar. I had one on a B and it worked well between fixings but the fixings were short lived,
The A and B were the only ones. What trouble did you have we had one on the B used it 15yrs on the cult only changed the rubber washer in the check valve every yr.
The Farmall F-12 and F-14 had an optional hydraulic lift driven off the other end of the belt-pulley, gear-box input shaft. Working a rock-shaft under the seat. Only the Farmall A, AV, B and BN had the pneumatic lift.
The damper in the exhaust got warped and stuck , so I bought a new one and took it out during the winter, Also the hose was a problem.
I still play with those systems and do repair ect but now getting out of stuff and I don't know where anyone has such stuff as I do get calls. Its always fun to take to shows and find out there were lots of them around and get comments on them pro and con mostly pro. The system was used on all the attachments for those tractors . Had a friend in Ill his wife found a rear planter with the system and they have restored it. I have only one left it is on an A-435 veggie cult that would do 6 rows on 15 center I just do one but the tool bars I have would do a lot more. The brackets that hold tooling is almost non-existent as they used flat bar along with round. The round brackets can be found but I have never seen ones for the flat bar. Has anyone else seen them for sale. I do have a bunch of the flat bar brackets.
