Joshbraman
Our 1586 which we have never had a issue with has
developed a serius problem this spring. I was out chisel
plowing and all of a sudden when you pick up at the end of
the field turn and drop back in the tractor tires stop. I know
it's not the clutch because I can can really drag the engine
down with the breaks. I have no problems with the steering
or brakes so don't think it's the mcv pump. It does make a
weird noise when it does this. The weird thing is it's random
and if I push the clutch in raise the plow let the clutch out then
go it doesn't do it. It's random? Is the ta having some
catastrophic failure? It has always worked but we have left it
in the forward position 99% of the time. Any ideas where I
should start?
should start?
