Gresen remote
I have a Greson remote with the casting number of 2701 on it. I have installed this remote to run a 3 point that I installed on a super c. The problem I'm having is that the control cylinder in leaking out the end that the control lever is attached to. Guessing that it just probably needs some new orings of somekind installed inside the remote. Problem is I don't have any idea how to go about installing the seals. Has anyone got a schematic that shows how the remote is constructed. Thanks Larry
(quoted from post at 18:10:47 05/12/17) Neither galvanized nor black pipe is rated for hydraulic applications (although many use it).
Sure was a lot of it used on factory built farmhand and Du Al loaders sold through the Dakotas and all around, 40's thru the 70's. May not be any good in modern systems but was used on those old low pressure systems.
Ok now that I have been scolded about my choice of piping can we get back to my original question. Does anyone have any info on a Gresen remote so I can think about putting new seals in my unit? Thanks Larry
