1456 Curved Hyd Lines
d282
Good Morning-
Does anyone know of a company making replacement lines for the hydraulic couplers in a 1456? The are the rubber lines out of the block with a 90 degree bend metal curve that has the hydraulic coupler. I blew one and would like to replace them as close to original as possible.
Thank you,
I think that any place that builds hydraulic hose can get a compression style hydraulic fitting that will clamp on standard sizes of steel tubing. Not familiar with the 1456 but if it has an inch or so straight shot before the bend one of these will probably work for you to reattach a new hose section to. The area where the compression fitting goes needs to be sanded "baby butt" smooth with emery paper to get a good seal.
