04 06 56 hydraulic valve anatomy
karl f
What is the purpose of the reverse flow poppet valve? I have a guess and I know from experience that if the o-rings on 22 fail or the poppet doesn't seat the load will drop or creep.
Karl f
Poppet is number 20
P.s. My guess relates to cylinder cavitation
As name implies, prevents reverse flow to pump. Has nothing to do
with holding a load up. When you have several hundred psi holding a
load and pull a valve lever, the oil in loaded cylinder tries to
flow toward pump before pump has time to overcome pressure in
cylinder.
(quoted from post at 07:04:06 04/29/17) Has nothing to do
with holding a load up. .
I mentioned holding a load because
5-10 years ago I bought a used valve from an individual who said he went through it. Immediately I had an issue with it holding the load, instant drop. Told the seller about it and he said the only thing he didn't look at or replace was the o rings on the check valve so to look at that. I removed the poppet retainer (22) leaving the remote assembly installed on the tractor and sure enough the o rings on 22 were degraded with cracks and tears. Replaced them and it held the load.
Karl f
If you will look at the schematic of those valves you see that the holding pressure is exposed only to the spool and any leakage past the spool will take a path to tank, not back to the check valve.
Also, anti cavitation check valves are not exposed to pump, as they are connected between loaded cylinders and possibly tank.
