We removed the timing cover to see if its gasket had covered the oiling port for the governor. It was unblocked,so we started the engine with the cover off to see if oil was coming out of the port from the block. No oil came from it. There only oil we saw was at the front main crankshaft bearing. So we do have oil pressure there. I'll post the pictures of what we are looking at.
Where does the oil gallery come from that oils the idling gear and the port that goes to the governor. I used wire to try to trace where the ports went in the block. The top governor port went down to the idler gear bearing, but from there I couldn't tell. Maybe the front camshaft bearing? Any ideas would be appreciated.
