Working on some hydraulic valves from a 504 according to the eBay seller. The back flow check poppets appear designed to have o-rings on them, except I found the o rings loosely tangled in the spring on both assemblies I'm working on. Part number on my list is 395277r1, with no listing of o ring, and current part number appears to be design without rubber seal according to messick's and bates websites. Have not found listing for o ring under 656, 806, etc. models. The poppet appears to fit liquid-tight without an o ring when I experiment in the parts washer. Should I skip the o ring and polish the mating surfaces with valve grinding compound to assure a seal, or must I replace with a new design poppet? I am sure any o ring installed will soon become lodged in the spring again or under the poppet itself. The bodies I have end in number 267 and have a 7/8 spool diameter.
Thanks
Karl f
Number 20 on the part diagram. 21, 23, 24 go on 22 not 20
Thanks
Karl f
