Oil cooler hose 1466?
Moline_guy
I need to replace the hoses on my 1466 that run from the firewall to the trans cooler up front, I picked up some oil hose rated at 300psi, it was half the price and not as bulky as 3000 psi hydraulic hose. The hydraulic place called it a "lola" hose. Will the 300 psi hose be sufficient?, I assume it is low pressure oil going through the cooler. Thanks for any help or information.
That should be fine. You obviously don't need 3000 psi hose since it's simply retained by clamps.
"LOLA" translates in "lock-on low pressure hose, neoprene".
