Hello all,
I have an IH 3444 with a gas engine. I am interested in adding a hydraulic remote to the rear so I can operate implements such as a raise/lower cylinder on a disc.
I imagine a guy could just splice off of the main hydraulic line coming from the pump and run it to a Power Beyond spool valve that would run to the remote ports.
But is there an easier way?
There is a plug in front of the seat that the book has labeled AUX, could this be used to run to the new valve instead of splicing?
Where do I run the return line from the spool valve?
Thank you in advance.
