Help Identify Flat Belt Pulley I-H, M??
glennstin
New User
I just received Two Flat Belt Pulley assemblies. One I know is the Pulley assembly and gear box for a Willys Jeep which mounts on the rear factory draw bar to run a Buzz Saw or other belt driven equipment. The second one looks like from a Farmall M maybe. It is much heavier than the Willys one, has a fiber pulley, the casting number is 358223R3 and an engagement rod about a foot long. I've never posted pictures on this Forum, but can email. I don't have an M, but have searched around here for a pix and found one I zoomed in. Please email me if you can add information. Thanks
358223R3 is a housing for 300, 350, 460 ETC or that size tractor with a T/A housing. Housing will work on H and SH tractors. Trouble is that number may not tell if the complete unit is the same because of different operating lever positions on different tractors. Some SH tractors used 358223R1 and some small changes were made to the housing after that. R3 housing give more clearance over the bolts in top cover of the T/A housing.
Seeing as how I put my shoes on took some pictures I'm postin them even tho you got your answer.
The bigger pulleys for IH tractors had more than 4 bolts. I have a large pulley on both my H and N and they have I think its 8 bolts.
WOW!! The knowledge around this Forum is Great. Thanks to all who helped out. My pulley is 9 1/2 X 8 on the Farmall unit held on by 8 bolts while the Willys pulley is 8X8. Now maybe I can help someone out who has a 300, 350, 460 and needs a pulley unit or parts as one corner of the housing is missing. It's Forums like this that helps keeping this old stuff like that Super H pictured above looking like brand new. Thanks Again.
