MARK ROBKE
I work part time(retirement pastime) at a local tractor repair/implement dealer/feed store.They used to be an IH dealer back in the day,family owned.So mostly what we work on is IH,usually a 474-3220,595-4210,and so on.When ever we replace a clutch,we have to adjust the fingers on the pressure plate.These are aftermarket reman clutches,from several different re builders.Do any of you run into this,or know of a re builder that sets the fingers correctly before hand?There is/was a tool to set the finger height, but we don't have it and can't find one.I worked on big trucks for 40 yrs and never had to set the fingers.I would not mind this so bad if we had the tool,but right now I am making an educated guess when I set them,and making notes.We are having flywheels turned including the step to the correct height.So any ideas,better re builders? Thanks,Mark.
