I believe the needle valve on the carburetor is not the correct one. If I close it completely the engine keeps running. My
question is how do you determine if you have the right needle valve, or if the needle or orifice in the carburetor is worn? I
can make a new needle valve, or ream the orifice if I know the correct dimensions. The carburetor is 361525R2. Any
suggestions.
Thanks
suggestions.
Thanks
