Thanks for your help on my Farmall C rebuild. Engine runs great. See Engine Rebuild, 03/21/17.
Now working on Cub that needs rings, as confirmed by compression test and valve check. Engine runs well but smokes. Standard 2.625 inch piston and ring, bore within spec, no cylinder scoring and no piston scoring. If I replace ring with standard my ring gap is .026, maximum spec is .017. Can I use a .010 oversize ring on a standard piston and bore?
