rgthompson
I have a 1949 Farmall H that is having trouble starting. It responds very sluggishly and only turns over a rotation of two at a time. It will eventually start after I have pushed and held the switch maybe twenty times. The switch (and cables to it) become almost too hot to touch before it will start and they will actually smoke if I try too many times. Once it starts, the switch and wires cools down. Although I am planning to switch it over soon to 12 volt, it is still a 6 volt system with the positive ground. The battery is brand new also. I am looking for any suggestions or was wondering if anyone else has had this problem before. Perhaps a bad ground? Or am I losing voltage across a bad starter? Any thoughts would be appreciated! Thanks.
