TractorLinks.com
Show Parts for Model:
SHIFTING LEVER REMOVEL ON H
S2710
04-21-2017 06:55:38
I am trying to get the shifting lever out of a H and I have both plugs out and I cannot remove the gear shift lever swivel small shaft. I have held down on the lever and had someone take a punch an try to drive it out with no avale. Is it got a groove wore in it holding it in place or could it be just rusted in place.The part number that I am trying to remove is 357003 R1. Thanks in advance.
Bob
rustyfarmall
04-23-2017 07:09:06
 Re: SHIFTING LEVER REMOVEL ON H in reply to S2710, 04-21-2017 06:55:38
Exactly! That 3 bolt cover wasn't used until the 300s were introduced.
tn terry t
04-22-2017 18:18:02
Quoting Removed, click Modern View to see never seen a h with a 3bolt shifter. well at least the two I have dont
tom dowling
04-22-2017 14:56:08
you might be better off removing the three bolts holding the assembly to the deck and working with it on the bench before you go beating it with a hammer
fbh44
04-21-2017 07:14:30
Hmmmmm... as I recall you're doing everything correctly. I do not believe there is anything further but to keep on keeping on. Maybe don't push down so hard? Maybe push harder?
Zachary Hoyt
04-21-2017 07:24:19
 Re: SHIFTING LEVER REMOVEL ON H in reply to fbh44, 04-21-2017 07:14:30
Some I have dismantled are worn more than halfway through the diameter of the pin. Sometimes they have a bolt in there that is bent. In any case, I would try jiggling the shifter around a bit and using a punch and a 2 or 3 pound hammer just bang away and you'll get it out eventually.
Zach
