I took off the range transmission cover to investigate some shifting issues. The pin holding the cam in place was sheared off, not good. The spring holding tension as it
is supposed to was gone, intact but in the bottom of the gear box. So no wonder there are issues. What I am concerned about is the sheared off head of a five sixteenths
black bolt which I am unable to figure where it comes from, whether looking at the shifter linkage pictures or the gear pictures. As well there was a woodruff key I
believe that would fit the shifting forks, though they both seem to be ok. There are two empty bolt holes just above the last gear either side it, but they are for a
three eighths bolt, and both are vacant. Any info would be appreciated, thanks.
