IAtractorKid
Hey guys! 656 is running great after getting her all back together
from the head work and new head gasket. By the sound of it, I'm
guessing the timing is pretty close but I would like to double check
with a light. Is 23 degrees BTDC at WOT correct for a C-263 in a 656
Hydro? Also, the tractor does have electronic ignition..Does that
change what the timing should be set at? Thanks!
