I have a 400d. It started on gas and switched over to diesel as it should.
but I failed to open the Diesel fuel valve and it ran dry after a couple minutes.
I've bled each injector and have fuel at all four,
It starts on gas but dies when I switch to diesel.
What am I missing?
(quoted from post at 01:22:24 04/19/17) I have a 400d. It started on gas and switched over to diesel as it should.
What am I missing?
Do you have good fuel flow out of the filter breathers?
Bleed primary filter with engine shut off. Bleed second filter with engine running. Then open the throttle a little and bleed each nozzle for a good spray. Should also show pressure on gauge at pump.
