Late 1953 Farmall H Found Hard To Find Tractor
Eddie V
Found a hard to find one 1953 farmall h #3916xx this is one of 372 h's that have all options like a early super h
best of all it within 30 miles of the farm.
We have a 53 H The front hubs on yours look different than ours. Not saying they are not the originals just different. Ours have the 3 oblong holes with the smooth outside to them if you know what I am referring to. Instead of the 3 spokes like yours. Otherwise it looks the same. After over 60 years might have changed them from a broke or worn out bearing bore.
For the 2 way hydraulics we just mounted a valve on the right side of the light bracket and tid the cultivator lever back with the rod off the tractor. Also have the lazy boy brake set on it. Home fashioned.
What I can find, there were 391730 of the H's made, ending in 1953. You sure saved one of the last. Good on you. Would be interesting to know what the various casting dates are, of the various heavy cast parts.
We have 391474, has a lot of super H features also. Has disc brakes, 10 1/2" clutch, pull loop for starter etc.Bought it for Dad before he passed away and still have it. Pat
