Spinner hand crank for Farmall / cub?
Luke470
I noticed that this site sells two tyoes of hand cranks. A regularvand a spinner. Whats the difference?
Also will and hand crank for the cub work in a tractor like a 130 or 200?
Thanks!
The spinner crank has a spinner on the handle so it spins when you crank it. The regular crank is just a bent piece of rod and your palm is the spinner.
Since you shouldn't have to go more than 1/2 a turn to get the engine started, it really doesn't matter. If you are windmilling the engine with the crank that you need the spinner to keep from getting a rub burn on your hand, that's a good way to get your thumb broke, but also your engine needs a tuneup.
Thanks for the info. I was curious if the
spinner was supposed to prevent broken bones
in the event of a backfire. A safety measure
of sorts.
(reply to post
at 06:54:46 04/17/17)
/list]
