:) My Farmall C starter turns, but won't engage. Pulled it out, oiled it liberally, turned the gear by hand and it came forward, placed it back in, but all it does is spin without any contact.
Can, someone please help? Thank you. Robert
where do you have the battery grounded at. try running your ground wire straight to one of the bolts that hold the starter on. my starter did the same thing on my super c
bass
Hi, Bass, I did try what you recommended and it still does the same thing. I will take it all apart maybe the spring needs changing or maybe
the gear is worn too much?
