Super H engine torque specs
I know that this has probably be said before but I
couldn't find it. I can't find the torque specs for the
super h but didn't know if h and super h were the
same.
Not sure what you are doing to your Super H but sounds like you need to buy a service manual. The I&T manual would be fine for bolt torque specs.
It isn't clear what you are asking for. Do you want engine output specs like HP and torque ? Head gasket torque ? Rod bolts...
Greg
FASTFARMALL - My I&T manual dates back to the 1960's and has torque spec's for everything like head stud nuts by steps, main bearing caps, rod bolts, rocker shaft hold down bolts, intake/exhaust manifold, etc. Has H, M, C, A, B, think even the Cub, and all the Supers and MD.
