Mr. Farmall
What I thought was a sticking needle valve has turned out to be something else. Engine will only run with choke half on, and it is still somewhat rough. It can idle without the choke but stalls right at half throttle with no choke. Installed a new needle valve, checked float height, and still no improvement.
I do not think it is a vacuum leak, as vac leaks usually hurt idle much more than part throttle or WOT. In my case, the idle is ok but throttle opening is the problem. I did still spray carb cleaner on the gaskets and did not detect any change in rpm. Hopefully the needle valve did not go bad right away but that is unlikely.
