Just a quick rundown of what is going on with my 1066 IHC.
We put in a rebuilt injection pump and couldn't get the tractor running. We ended up taking the valve cover off to check timing. Found a bent rocker arm and mushroomed pushrod both on one cylinder.
When pulling out the other pushrods to check them out, something went wrong with one of the rods. It seems like something fell over inside the engine. We are not able to stick it back down as it should be.
Any thoughts what happened down there and can it be fixed without yanking the head?
Thanks
Thanks
