I am trying to replace the front wheel bearings on my Farmall A. I purchased kits from Steiner. As I am taking the old set off; there is a metal piece behind the inner bearing that appears to have had felt or leather washers (badly deteriorated and unrecognizable) sandwiched in between two metal rings. The new set has two felt washers with what looks like a sheet metal cup. I am not sure if I am missing a part. I don't see the purpose of the cup. I don't know about using the old part. I can probably straighten the spots where it got bent during removal; however I don't know how to get the felt washers onto it without damaging them. Also there was a metal ring in it that broke apart. If I use the sheet metal cup in the configuration that it appears to go, then the back of the inner bearing would be against the felt washer; whereas on the old one it was against the metal retainer that held the felt or leather washers. Any help would be appreciated.
