wallypedal
New User
I'm just into Day Two of owning this 400. Today, I hooked up a cultivator/packer that has power down wheels. The tractor had a pair of lines to the rear and I made connection OK. I'd used this implement recently and knew that the power up/down worked fine and has a newer cylinder on it. It seemed like I just wasn't getting enough psi to make it move quickly at all. On the right side of the tractor below the tank is "Brand" flow control valve. At medium rpm, I went ahead and moved that valve to the point it started squawking, so backed off. I did find a setting where I had decent response to the wheel up/down cylinder. Questions: Was this an add-on valve? What is it supposed to do? I've just started searching forums, etc.
I do have hydraulic seep (not drips yet) coming from the valve block area. Will look at that soon.
I rebuilt and tightened up the parking brake mechanism - sweet, when it does what it is supposed to!
Had a little trouble starting, until I discovered the choke cable had come loose from the clamp on the carb end. I think I'll have to pull the cover and the shaft to get it freed up and working right. Pretty sure it pulled from the clamp because it was bound up elsewhere.
Any advice appreciated!
Wallypedal
Wallypedal
