Just finished my Farmall C engine rebuild with a Reliance rebuild kit. Kit instructions said to 'not' remove pistons from sleeves to avoid damage to rings. Pushed pistons far enough down to connect to crankshaft without exposing rings. Seemed to assemble with no problem. Head recently redone, valves closing and opening as they should. New head gasket torqued at 65 lbs.
Engine has not been started and run. I did a dry/cold compression check and all 4 cylinders are 30 psi. Do I have a problem? If yes, would I get 30 psi if there were no rings on the pistons?
