b farmall carb issues
bigsarge
New User
i just rebuilt the carb. it will only run if I have a rag with gas on it over the intake of the carb. ive taken it apart 3 times and blew every little hole out and made sure nothing is clogged up. the bowl has gas in it so I'm at a loss of where to go now.
May or maynot apply, but I seem to remember my "H" venturi has s tiny hole drilled in it for gas to get pulled thru. That's how the thing works. You might make sure, if you have such a tiny hole, it lines up with an inlet hole for gas to flow.
I will try the wire cleaning and make sure the venturi is lined up right. Im pretty sure thats what it is. Thank you everyone for the info. :D
(quoted from post at 07:06:47 03/22/17) May or maynot apply, but I seem to remember my "H" venturi has s tiny hole drilled in it for gas to get pulled thru. That's how the thing works. You might make sure, if you have such a tiny hole, it lines up with an inlet hole for gas to flow.
You are thinking of something else. An H venturi does not have a hole in it, and it will fit only one way. It cannot be installed upside down. It physically will not fit.
