Super H Cam Bearing
Has anyone ever replaced the cam bearings
themselves and if so where did you find the soft
plug at the end. It is common to fine at a parts store
or is it something special.
The plug (or a replacement that works is common. THe cam bearings are not easily or (usually) successfully replaced without the alignment drivers. Very low success and oil hole certainty when using home made drivers unless you make them the same as professional special tools. With the correct drivers no issue. Jim
