One more Super M question
I went to look at a Louisville Super M tonight, serial number L508XXXJ 3 bolt starter, live hydraulics, battery under seat, starter a choke loop rings on left side of steering support but no hydraulic box under gas tank used the vacant spot where lift all pump for reservoir what gives?????
It would be a stage 1 SM 8000 into production 1952. It would have had the live pump added then used the reservoir (with or without the pump still in it) of the belly pump for a reservoir only. Pretty common adaptation. Jim
Seems like it would be a 52 Look to the left (serial numbers) It could be a 53 if they made less than 8000 in 53. Jim
Everything I have looked at tonight says that Stage 2 production began at serial number L504802 so that would make this tractor 3,258 later than that?????
Live hydraulics was a "delete option" for the Stage II Super M. That could explain vacant spot under the gas tank.
Stage 2 chassis changes were made to accommodate the engine driven hydraulics. But after stage 2 serial number start they could be equipped with countershaft driven hydraulics also. Bracket like the picture was only used on stage 2 tractors with a counter shaft driven pump.
Definitely a stage II SM 1953. 501906 was the first Louisville SM serial number. Most likely it was ordered as a factory live hydraulic delete. 53's still had the provisions for a belly pump and that was an option.
My 53 has live hyds. If it were ordered with live hyds and no belly pump it would have a cover where the counter shaft drive would be.
Its easy to swap in a live hyd pump.
Not to hijack, but do you have a good pic of the other end of the choke rod setup at the carb? The one on my SMTA is bent a bit and doesn't close the choke correctly, have to choke it manually. Looking to correct the geometry to get it working right
Can't get one tonight. No sharp bends except at lever and hand eye in a SMTA choke rod with choke lever on engine side when mounted. Just checking, if someone put a M carburetor on it with a choke lever on outside could that be the reason for the bends?
