TractorLinks.com
Show Parts for Model:
Farmall H not starting
cower50
03-19-2017 16:52:26
I can now get a backfire through the carb air intake if I shut the gas off and hit the starter a couple times. Then white smoke comes out Thur exhaust and then I can't get anything else until I turn the gas back on.. turn it over awhile... then turn gas off and I'll get another backfire. Does this mean anything in particular to anyone?
cower50
03-20-2017 19:27:00
 Re: Farmall H not starting in reply to cower50, 03-19-2017 16:52:26
It's a mag. Have good spark at plugs. When done cranking gas pours out the air intake that I took off. I figured that's normal when it doesn't take off and the excess gas comes back out. I'm going to try to time it this Wednesday when I get time but how would I have screwed the timing up if I didn't take mag off?
riverbend
03-21-2017 06:10:40
 Re: Farmall H not starting in reply to cower50, 03-20-2017 19:27:00
Gas shouldn't run out of the intake tube. It is flooded. Is your choke stuck shut or the float sunk or jammed ?
Greg
riverbend
03-20-2017 08:12:34
Mag or distributor ? I'm only familiar with he distributor ignition, but start with the basics. Is there power at the points with the switch on ? Do the points close and ground out the ignition ? Spark at the coil ? Spark at the plugs ? Spark when you set the timing ? After that, bad coil, condensor, rotor, cap...
It is probably something straight forward.
Greg
Janicholson
03-19-2017 20:10:40
1342 from the front to the back. #1 on the cap is (usually) in the 1:30 position looking from the back. then clockwise 3,4,2.
The points are set at .020" on the point of the distributor cam. Jim
cower50
03-20-2017 04:50:40
 Re: Farmall H not starting in reply to Janicholson, 03-19-2017 20:10:40
Last running about 4 months ago when I brought it in for a repaint. Ran great then
Janicholson
03-20-2017 06:17:09
 Re: Farmall H not starting in reply to cower50, 03-20-2017 04:50:40
Paint can change ground and connection conductivity. If you took some electrical components off, start with their connections and grounding through paint. Jim
David G
03-19-2017 18:20:59
When did it run last, and what have you done since then?
kevinj54
03-19-2017 16:57:50
Ya, check the timing
