Brownie450
1953 cub---putting on piston rings, & the instruction sheet
shows the 2nd ring with bevel up.
The "pip" on that ring would be down if the bevel is on top.
I was always taught that the "pip" should be installed up on
rings. What is your guys thinking on this?
The old top ring---which I assume to be original---is bevel
up, & the second compression ring is flat---no "pips"
This is a PRS60 ring set.
Thanks.
Jim
Thanks.
Jim
