simcross
826 with front blade, rear weights, axle mount duals, rear chains on duals to save fenders from a beating. Now the question will this put to much stress on rear axle or rear end? Thanks
Doing what, exactly?
Frankly if you are thrashing around so hard that the chains would sling out and hit the fenders, I think you'll tear up the tractor in that configuration.
If you can't get around with duals you need to wait for conditions to improve or get better tires.
Your rear end can handle it. but if your ramming bushes, small tress or trying to do work of a bulldozer, you will tear that right up. a tractor is a tractor, not a bulldozer. if your plowing snow, and you put duals on because the ice is to great, your very safe. just have a feel for it while pushing... if you feel in your heart that the 826 is crying in pain then your over pushing it.
