52 farmall super a final drive bearings
gidtex
Needing cross over number for
st278,st205a,st239.the one i found had one
less ball on the st278 bearing.also the
inside and outside race was notch on st278
bearing.is the bearing with notch race call
a maxi capacity or multi fill.will a regular
bearing be ok with one less ball.thanks
The number of balls will not matter. The notch is there to aid in installing balls. Had a talk with the SKF tech years ago. Ran into this a lot in my years of pulp mill maintenance.
Go to the link below and then click "Interchange" and enter your part number.
All your numbers cross.
As to ball count, it MAY matter for high load, high HP applications, which hardly describes a "Super A".
