SkookumJack
New User
Just rebuilt an IH 504 utility. New clutch parts & bearing carrier were installed. After setting the clutch adjustment to the manual prescribed sets, I find I do not have enough push to open to engage the clutch.
I assume the pressure plate comes adjusted. I installed it as it was, but noticed the pressure arms were almost flat when bolted on tight.
I noticed that the woodruff keys on the fork actuator arm shaft were out and I put them back in place. Thus the fork that works the throw-out bearing can only be in one position? Could I take the woodruff keys out and readjust the fork position without the woodruff keys?
