CUB OIL PAN GASKET
kfnut
I need to replace the oil pan gasket and looking at the pan , it has three bolts at the rear that seem hard to reach unless the motor is separated from the clutch housing . Is there an east way to reach these to remove and install ? The manuals give no clue .
Many years ago I replaced the pan gasket on my Cub. As I recall I used a 1/4 inch drive socket with a universal joint and a 6 inch inch extension. I took my time doing it and all worked out well. There was no need to take anything else apart.
Thanks guys . Looking at it closer today , I might be able to get in there by swivel joint socket or bending a wrench to fit in . I also found a bolt , on the front end , that the head is broken off . That may be the hardest one to get out . The gasket is decayed badly and will have to be replaced .The high pressure hot water cleaner also found other flaws too .I will attack them one at a time .
