I purchased a Farmall tractor, I was told by the seller that it is a 1949 Farmall super A. However from everything I have read the casting numbers say that most of the tractor was manufactured in 1950 and the engine was manufacturered in 1951. The engine also appears to be a Farmall C engine based on the stamped serial numbers. Here are the numbers that I have found to help identify it. The serial number plate on the seat bracket is not there.
Engine serial # FCM G 74240
Engine casting # 1*4*U(w maybe) and 251089 R1
Hydraulic housing # 8*7*T. And 354352 R1
Torque tube # 11*6*T and 351687 R3
Transmission # 11*24*T
I will try to figure out pictures
