Noblefarm43
New User
I'm putting the D-179 motor back together in
my 464 and I've run into a problem. The I&T
manual I have says to put the side of the
rods with numbers stamped on them towards
the camshaft side of the motor. I'm about 90
percent sure this is opposite the way I took
it apart. For one the notches that hold the
bearing in place are opposite from the
syltamped numbers and I think the notches
were on the camshaft side. Secondly the
stamped numbers don't reference which
cylinder the rods go to. The first rod is
stamped 246 on both rod and cap and the
third one is stamped 544. Other motors I've
done had dots corresponding to cylinder
number or exact number stamped on them.
So does anyone have knowledge of or a
different manual that tells how to install
the rods in reference to the bearing notch
or the flat side on the wrist pin end of the
rod rather than stamped numbers?
Thanks
Thanks
